I have some problems using UltraRibbon.
If I set the FormDisplayStyle in the UltraToolbarManager to 'StandardWithRibbon' my icon is displayed very curious. Resetting the value to 'standard' shows the icon as it should.
Is there a way to set the iconsize?
Any Ideas?
greets Nico
Standard:
StandardWithRibbon:
thank u so much. You're absolutely right. My icon file consits just one image. That was my fault. I created a new one and it works fine.
Thank you
Nico
Hello ,
Could you please let me know how many bmp your icon contains ? is it possible to post your icon in zipped format ?
When FormDisplayStyle is set to StandardWithRibbon the form displays normally based on its FormBorderStyle property settings and it also includes some Ribbon elements in the caption area, such as the QAT and Contextual Tab Group labels. Ribbon will select bmp from icon based on the resolution and operation system, if it couldn’t find appropriate icon it will select the available one, so it seems to me that your icon has only one bmp. For more information about the Icon guide lines please look at the following link:
http://msdn.microsoft.com/en-us/library/windows/desktop/aa511280.aspx
