330
Assign Calculated Column to a Ultragrid group
I have an Ultrawingrid to which i am binding some columns from the Database. I group some of the columns with the Ultragrid group so that the result set comes up as below
Now using the ultrawincalc manager the user can add new calculated columns. can the user choose which ultragroup the columns should be added to? like can he choose the new column to go under any Group?
Also if the Datasource is empty can i set a No records message? if so how?
