Hello guys,
I want apply different styles to an UltraTextEditor field at runtime, depending of the state; Read-Only, Required or Optional, as shown. is this possible with AppStylist?
To learn more about the Infragistics Application Styling Framework (ASF), please visit our online help documentation found by clicking here. Please let me know if you have additional questions about using styleSets.
Thank you very much. It works OK and is just as intended. And YES, this has allowed me to understand the inheritance and how style sets works.
Alfonso
I've attached a simple project which I hope will not only solve your problem, but will also help you understand how style sets work.
In the isl (style library), I have defined 3 additional style sets which only modify the background colour of the text editor. Everything else is inherited from the default style set, and is unmodified.
I've added 3 text editors on the form, and in code you can easily set the corresponding style set for each one of them:
txtReadOnly.StyleSetName = "TextEditorReadOnly"; txtRequired.StyleSetName = "TextEditorRequired"; txtOptional.StyleSetName = "TextEditorOptional";
There are more controls on the form which are styled by the default set and are unaffected by our additional styles.
Hope this helps,
Cosmin
The previous isl file is the original (default).
Attached to this post is the modified with the added styleset.
Sorry, but I have tried to define additional style sets for the UltraTextEditor control, changing only the back color and allways get this as the resultant color, at least at the Editors tab of the appStylist program. I don't have tried this on code yet.
I enclose my isl file. Can you make a sample? thanks
