1590
Print preview of day view & actual view of day view, both are different
 I m using ultra day view, and the UI of utlra day view is fine...but the same day view is not showing properly on the print preview...the seprator line among days are hiding...which gives a bad UI...is this happens due to flaw in control or some thing else?  Please help regarding this issue.
Thank You
  • 230
     Are you referring to the interval lines? It seems that it will look at the amount of space available and if too little will hide the :15 and :45 minute marks. If you change the StartTime and EndTime to a smaller window, say 4 hours, then you will have lines at :00, :15, :30, :45.
    I haven't figured a way around it yet either.
