600
Can you remove the PromptChar display completely?
Hello all,
I have a UltraWinGrid and in it some cells have to take a positive float. Typically the value will be in the 1,000s or 10,000s and so I use a MaskInput = "99999.999"
Using the value 1234.56 as an example, the data in these cells display fine when they aren't in edit mode. However, in edit mode the display includes the PromptChar:
1234_.56_
The Infragistics knowledge base (http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10078) says that to get remove of the prompt char you set it to ' ', but this isn't removing the PromptChar it's just replacing the underscore with an empty space:
1234 .56
Which to my eyes just looks wrong and ugly.
Given that there is no equivalent of string.Empty for the char data type, and I've tried a null char ('\0' http://stackoverflow.com/questions/3670505/why-is-there-no-char-empty-like-string-empty) with no success, the question is, how can I get an the same display in edit mode as in non-edit mode i.e. 1234.56, but also have a filter to restrict the data type?
Note: If I remove the MaskInput it works fine, but then you can put in any characters you want and this data can only be positive numbers.
