1940
Tree Scrolling after Datasource change
me again :)
I just came across the following:
I have a data bound tree, ViewStyle is "OutlookExpress"
Lets say we have a lot of nodes and the tree needs to show a vertical scroll bar.
Lets say we remove the object from the datasource which is behind the very first top node. This will remove the node. The top node is now something else. Now we add the object to the datasource again. This will insert the node at the top position. The scrollbar is now unable to scroll up to the new just added top node, even we know the node is there. After scrolling _DOWN_ and then _UP_ it will show the node as excepted.
I just upgraded to 11.2.20112.2074 and I was hoping it will fix this, but I can still reproduce this error.
I also have read that this might be known issue and will be fixed with a service release in late may, we have june now. Is there any fix coming soon? I just want to make sure.
Blue
