We are using NetAdvantage Winforms 2007 Volume 2. Recently we applied the hotfix. We use winChart. It used to work before the hotfix. But after the hotfix, when the width of the chart is not wide enough, the x-axis labels get squeezed to the far left, or even disappears. When I resize the chart to make it bigger, the x-axis label starts to show up at some point.
What could be the problem and how can we fix it?
Thanks.
Zongwen
thanks for the sample. i see the problem now, and i have entered this into our bug tracking system as issue #BR35146. it should be resolved in a future hotfix. to inquire about the status of this bug in the future, please contact infragistics developer support.
Finally I got the turn to make a sample program to duplicate the problem. Could you please try it out!
ok, i see ... could you post some sample code for this, or submit a support issue? obviously there is a problem, but i'm not sure how to reproduce it.
i would also recommend testing with the next available hotfix, because the axis label layout feature has gone through quite a few changes in the past hotfix cycles.
the pictures is not showing up, let me post it again here:
<a href="http://picasaweb.google.com/fengzongwen/Chart/photo#5197646603423182018"><img src="http://lh3.ggpht.com/fengzongwen/SCHADCkN7MI/AAAAAAAAAfo/rCrYfayOxsg/s144/chart-large.JPG" /></a>
<a href="http://picasaweb.google.com/fengzongwen/Chart/photo#5197646607718149330"><img src="http://lh4.ggpht.com/fengzongwen/SCHADSkN7NI/AAAAAAAAAfw/JMUt38ENGFA/s144/chart-middle.JPG" /></a>
<a href="http://picasaweb.google.com/fengzongwen/Chart/photo#5197646612013116642"><img src="http://lh5.ggpht.com/fengzongwen/SCHADikN7OI/AAAAAAAAAf4/q4KLr3toQJA/s144/chart-small.JPG" /></a>
i have behavior to ratate 45 degree, so i can't set the behavior to none. Anyway, I tried to set it to none, the problem still exists.
Here are some pictures showing when i resize the chart from large to small, the x-axis label begins to be squeezed to the left size out of boundary.
