265
Vol 12.1 Installation Help
When I am trying to install the infragistics vol 12.1, the following log is been generated.
02:05:52: Log file initialized at: 6/5/2012 2:05:52 PM
02:05:52: Version number of the executable is: 12.1.20121.1001
02:06:00: Local installer C:\ProgramData\NetAdvantage_WinForms_20121_WithSamplesAndHelp\Setups\NetAdvantage_WinForms_20121.msi was found.
02:06:02: Local installer C:\ProgramData\NetAdvantage_WinForms_20121_WithSamplesAndHelp\Setups\NetAdvantage_WinForms_20121_Samples.msi was found.
02:06:04: Local installer C:\ProgramData\NetAdvantage_WinForms_20121_WithSamplesAndHelp\Setups\NetAdvantage_WinForms_20121_Help.msi was found.
02:06:04: Local installer C:\ProgramData\NetAdvantage_WinForms_20121_WithSamplesAndHelp\Setups\NetAdvantage_VersionUtility_20121.msi was found.
02:06:04: Checking proxy settings...
02:06:04: Proxy not found on the system!
02:06:13: Object reference not set to an instance of an object.
02:06:14:    at Infragistics.Wrapper.Interface.Utilities.IgWebClient.UserDialogAuthenticateProxy(IWebProxy proxyInformation)
   at Infragistics.Wrapper.Interface.UI.InitializationForm.StartInitialization(String[] commandLineArguments)
   at Infragistics.Wrapper.Interface.Program.Main(String[] args)
02:06:14: NetAdvantage_Ultimate_20121.exe has completed.
02:06:14: Log file complete.
Kindly Help on this.
