Normal 0 false false false EN-US X-NONE X-NONE
We have a requirement to show visual indicator like a border or some other sort of indicator around a control when control gets focus. Is there a way to achieve this through built in property? It’s hard to handle through Gotfocus and LostFocus events manually for 1000+ forms.
Hello ,
Please let me know if there is anything else that I could for you regarding this issue.
Basically there is no way to have style do this for us (other than text editors)?
Thanks for your help!
What you could do in your case is to handle paint event of the component, on which you need to draw this rectangle and to draw it in this event. You could use code like:
private void Form1_Load(object sender, EventArgs e)
foreach (Control c in this.Controls)
if(c is UltraComboEditor || c is UltraCalculatorDropDown || c is UltraDateTimeEditor)
c.Paint += new PaintEventHandler(c_Paint);
void c_Paint(object sender, PaintEventArgs e)
if (((Control)sender).ContainsFocus)
e.Graphics.DrawRectangle(new Pen(new SolidBrush(Color.Green), 2), ((Control)sender).ClientRectangle);
Also please see attached sample.
Also, with visual studio 2005 style it still can't add rectangle around combo box, drodown, calendar dropdown and date time editiors.
I need to show this for all the controls as this is one of section 508 requirement from one of our client.
Any Ideas?
Thanks for follow up. I have got some time to play with style. I think we can acheive with visual studio 2005.
is there a way we can acheive this with current 2010 based style?
