I have an ultragrid and ultrachart...according to the data in the grid the data is displayed in the chart.Suppose i have got only one record in the grid the output which i get in the chart is shown in the attachment(Sample).The width of the columns is too big and i want to reduce its width. i tried using below code,but then the column space between the two bars became more as shown in attachment(Sample1)
Private Sub UltraChart_ChartDrawItem(ByVal sender As System.Object, ByVal e As Infragistics.UltraChart.Shared.Events.ChartDrawItemEventArgs) Handles UltraChart.ChartDrawItem
If ds Is Nothing Then Exit Sub
If dt.Rows.Count <= 3 Then
Dim columnWidth As Integer = 15
Dim box As Infragistics.UltraChart.Core.Primitives.Box = TryCast(e.Primitive, Infragistics.UltraChart.Core.Primitives.Box)
If box Is Nothing Then
Exit Sub
End If
If box.DataPoint Is Nothing Then
Dim dWidth As Integer = box.rect.Height - columnWidth
If dWidth <= 0 Then
box.rect.Width = columnWidth
box.rect.X += dWidth / 2
End Sub
I've been chasing this for a while and the sample code didn't work for me either.
Then my boss came up with a very usable workaround: Just create a handful of empty rows in your datatable. The empty rows make the actual columns smaller and much better looking.
The "empties" aren't visible and everything autosizes properly.
I am using infragistics 2013 and i am using column chart in which i want to fix the same width to all the columns in the chart.
Please help.. Its urgent... please share some example to to achieve this scenario. And i also tried using ColumnSpacing & SeriesSpacing but didnt worked for me.
Thanks in advance ..
H,
There are many approaches to solve this task, but the easiest way to achieve desired look and feel is to use both properties:
- ColumnSpacing
- SeriesSpacing
sorry forgot to upload the second attachment Sample 1
