695
UltraGrid with different controls on each row of particular column.
I am using Ultragrid for some set of properties which should be applicable to some data.
which is the best way to implement different controls inside a cell.
For example consider a grid with 3 rows with 2 columns. All the below controls are applied on the same column (2nd column).
1) First Row second column should have UltraComboEditor
2) Second Row Second column should have UltraCheckEditor
3) Third Row Second column should have TextBox (not using UltraTextEditor because of lack of support for autocomplete text). Is the autocomplete added to UltraTextEditor ?
Which is the easy and more performance way to implement the same. If possible, give me a sample application which explains it.
How to retrieve the data from the each type of column ?
Is there any control which may help improve the performance if it is used inside UltraGrid. if yes, kindly explain them.
