Hi ,
I have a plot like this :
I would like to shift the why axis to the label , I use the followinf fillscene graph :
private void Chartquadrant_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e) { foreach (Primitive item in e.SceneGraph) { if (item.GetType() == typeof(Line) && ((Line)item).lineStyle.DrawStyle != LineDrawStyle.Dash) { if (((Line)item).p1.X == ((Line)item).p2.X) { ((Line)item).p1.Offset(this.Chartquadrant.Width / 2, 0); ((Line)item).p2.Offset(this.Chartquadrant.Width / 2, 0); } else { ((Line)item).p1.Offset(0, -400); ((Line)item).p2.Offset(0, -400); } } Text pl = item as Text; if (pl != null && ((Text)item).labelStyle.Orientation == TextOrientation.VerticalLeftFacing) { ((Text)item).bounds = new Rectangle(((Text)item).bounds.X + 0, ((Text)item).bounds.Y - (400), ((Text)item).bounds.Width, ((Text)item).bounds.Height); } if (pl != null && ((Text)item).labelStyle.Orientation == TextOrientation.Horizontal) { ((Text)item).bounds = new Rectangle(((Text)item).bounds.X + this.Chartquadrant.Width / 2 - 50, ((Text)item).bounds.Y, ((Text)item).bounds.Width, ((Text)item).bounds.Height); } } }
Do you have any idea of how i can do that ?
Thanks.
F.
Hello F,
Have you been able to resolve your issue ? Did you have a time to take a look at the attached sample.If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
Regards
I suppose that we discuss similar topic with you in another forum thread. If you want to change the Axis posiition you should used :
((Line)item).p1.Offset(this.ultraChart1.Width / 2 - 23, 0);
In this sample I have additional offset of (- 23). This will move only my axis, so I should apply the same offset for the labels. For example:
((Text)item).bounds = new Rectangle(((Text)item).bounds.X + this.ultraChart1.Width / 2 - 23, ((Text)item).bounds.Y, ((Text)item).bounds.Width, ((Text)item).bounds.Height);
The same approuch would be for the other axis and lables. Please take a look at the attached sample for more details and let me know if you have any questions.
