We are using version 9.1.20091.2029.
I know you can move tabs around in the mdi from vertical to horizontal, but is there a way to move a tab from the mdi to another monitor. The same functionality that visual studio offers?
Thank you,
Brandon
If you take a look at the sample when we want to drag the MDIChild form out of the MDIParent form, we should drag relevant DockArea-> Pane, so it should be visible. Of course this will change our look and feel.
Regards
Thanks for the updated solution. I see the change you made, but I loose my tabbedmdimanager look and feel when i use dock areas.
Is there a way to keep the same look and feel as tabbed mdi children and also drag ourside the mdimain?
Thanks for attached sample. I made small modifications into your project, because there are missing this code:
Friend Sub LaunchForm(ByVal frm As BasePageMdiChild) Try frm.WindowState = FormWindowState.Normal frm.Show() frm.MdiParent = Me dockManager.DockAreas.Add(UltraWinDock.DockedLocation.DockedTop, "TopArea") Dim da1 As New UltraWinDock.DockableControlPane(frm.Text, frm) dockManager.DockAreas("TopArea").Size = New Size(Me.Width, Me.Height - 80) dockManager.DockAreas("TopArea").ChildPaneStyle = UltraWinDock.ChildPaneStyle.TabGroup dockManager.DockAreas("TopArea").Panes.Add(da1) Finally Me.Cursor = Cursors.Default End Try End Sub
Try
frm.Show()
frm.MdiParent = Me
Finally
End Try
End Sub
Please take a look at the attached sample and video file for more details and let me know if you have any questions.
I created a test solution. Please unzip and run. Cick Open Form and then try and draw the form away from the mdimain.
The file was to large to attach, so I uploaded to googe docs.
https://docs.google.com/open?id=0B8PQ2JBwhZrAMmFPTjIwcVF0MmM
Thank you for your help.
Hello Brandon,
Thanks for the video. I try to reproduce your issue using the same version, but without success. Are you able to modify my sample to reproduce your issue. I`ll be glad to research your scenario.
