240
Problem with reset to default after ungrouping in UltraGrid
If I group by dragging any column to the Grouping box in UltraGrid, that column will be removed from the grid and Group tree will hold that column. if I disable the grouping (Ungrouping)using code how to re add the column back to the grid. I mean how to do the un-gouping dynamically using code.
Please Help me.
Thanks in advance.
Kishor K
  • 469350
    Hi Kishor,
    Grouping is tightly tied to sorting. So you could clear all of the grouping and sorting in the grid like this:
    this.ultraGrid1.DisplayLayout.Bands[0].SortedColumns.Clear();
    To unground and unsort a single column, you remove it from the SortedColumns collection:
    this.ultraGrid1.DisplayLayout.Bands[0].SortedColumns.Remove("My Column");
