Mike,
I am using Infragistics v11.2 service release 2004. I am facing a small issue while using Round up and Round Down.
When i give the value below "0.0901" and roundup the value using "Calcmanager" i got error "Specified cast is not valid". Is there any logic behind this problem?
I attached a sample application with post.
Steps to reproduce the error.
a) Run the application
b) Enter value 0.0901 or above in Round up or Round down control
c) Click "Calc" button
d) Result : The value will post in the Result control
e) Now enter value "0.0900" or below.
f) Click "Calc" button
g) Now we got the issue "Specified cast is not valid"
Guide me to solve this problem.
Hello sureshsimkumar,
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
Thanks for the information. I will check and give you feedback.
Hi
I tried this out with the latest service release (build 2050) and I am not getting any exceptions.
