350
Saving layout
AM using wingrid 10.3
Saving layout as follows
grdData.DisplayLayout.SaveAsXml(path & "\" & strfname, PropertyCategories.All And Not PropertyCategories.ValueLists)
and laster reloading as
grdData.DisplayLayout.LoadFromXml(path & "\Layout", PropertyCategories.All And Not PropertyCategories.ValueLists)
It working fine, But if i add any new columns that are missing once layout loaded.
And also Columns that are not editable becomes editable.
Please help me
  • 469350
    Suggested Answer
    Loading a layout into the grid will replace any existing layout information. The layout includes the columns and bands, so if you need to add new columns or make sure that some columns are not editable, you need to save a new layout with that information in it - or else you need to re-set those properties and add those new columns in after you load the layout.
    Another option would be to load the layout into an UltraGridLayout variable, instead of  directly into the grid.DisplayLayout. Then you can modify the layout and then use the CopyFrom method to copy the layout into the DisplayLayout.
