This is a bug report
I have a 91 Error when I use method Generatepreview with Infragistics.Win.Printing.UltraPrintPreviewControl.Error occurred after installation of the security update for the .NET Framework 3.5.1 on Windows 7 Service Pack 1 and Windows Server 2008 R2 Service Pack 1: April 10, 2012
If i uninstall windows update, no more error.Error also disappeared if I put DisplaypreviewStatus to True.
Best regards
Regis
The fix for this issue has been resolved in NetAdvantage 2011 Volume 1 and newer. To take advantage of this fix, please download the latest service release using the instructions found here: http://community.infragistics.com/forums/t/29398.aspx
We are in the process of review all details pertaining to this issue. I will be sure to update this forum post as soon as more information becomes available.
Hi
having the same issue here. Is there already a solution for this problem?
Thanks a lot for your help
Reto
I will be happy to help you out with this issue.
I have created case # CAS-89222-N38SDS for you to better assist you with this issue going forward. To access the case, simply log into your IG account and click on My Support Activity.
Please let me know if you have further questions in this matter utilizing the case created.
