for layout purposes I wanted to use WinPanel but this is unfortunately not having any padding capabilities. Instead I now misapply WinGroupBox as a panel by setting the Text property to an empty string and the border to None. With the ContentPadding properties I can set the padding to the underlying controls which works fine so far.
Yesterdeay I detected that the WinGroupBox seems to have an initial padding of 1 pixel to the left, right and lower edge since when I add just one control, set Dock property to Fill, ContentPadding to 0,0,0,0, this control has Location set to 1,0, the width is 2 pixels smaller and the height 1 pixel smaller. If I do the same with a WinPanel (or MS panel) the underlying control will have exactly the same dimensions as the panel.
Is this a correct behavior or a bug? I would appreciate if the WinPanel would offer the possibility to set the padding since imho that is one of the basic features to expect from a panel. I wrote a feature request for it just this morning.
Regards,Wolfgang
Hello Wolfgang,I wanted to know if you were able to test this behavior with the latest service release for 11.2 and 12.1 and if it worked for you.Please do not hesitate to contact me if you need any additional assistance.
Hello Wolfgang,
I created the following case for you: "CAS-89116-RHSKK5" and will update you through it.
