Hi I woul like to add a horizontale line at zero on the x axis on my composite chart.
I tried this :
IAdvanceAxis x = (IAdvanceAxis)e.Grid["X"]; IAdvanceAxis y = (IAdvanceAxis)e.Grid["Y"]; if (x != null) { int target = 0; int yTarget = (int)y.Map(target); int xStart = (int)x.Map(0); int xEnd = (int)x.Map(5); Line line = new Line(new Point(xStart, yTarget), new Point(xEnd, yTarget)); line.PE.Stroke = Color.Red; line.PE.StrokeWidth = 3; e.SceneGraph.Add(line); }
But nothing appears.
Any idea ?
Excellent it works thanks for the tip
Generally your line is there, but it is not visible, because your Axis X is over the line. To solve this task we have two options.
Option 1: We could used Range properties. For example:
- RangeType = Custom;
- RangeMin = - 50;
-RangeMax = 100
By this way we could change the range of your Y axis and when your chart line has zero values, they will be visible.
Option 2:
We could used LineAppearance properties and we could change the Thickness of the line. For example:
LineAppearance la = new LineAppearance(ultraChart1); la.IconAppearance.Icon = SymbolIcon.Circle; la.IconAppearance.IconSize = SymbolIconSize.Large; la.LineStyle.EndStyle = LineCapStyle.DiamondAnchor; la.Thickness = 8; LineChartAppearance lca = new LineChartAppearance(); lca.LineAppearances.Add(la); myColumnLayer.ChartTypeAppearance = lca;
la.Thickness = 8;
I made small smple for you using my second approach. Could you please take a look at the attached sample for more details. Let me know if you have any questions.
Regards
