I am using Ganttview and calendarInfo data source property. If project startdate is 2/24/12 and task startdate is 3/10/12 then when I load data gantt view it show task startdate 2/24/12(i.e project startdate).So it is possible that task start date should be same as in DB?
Hello Imran,
Could you please try to leave project`s StartDateTime to be Null and let me know what is the result.
If you have any questions, feel free to write me
Regards
I am experiencing similar issue as well.
I am building my Tasks from database. For that I create Project as well. I give start date of project, as start date of First Task.
I give different Task Start Date but still when I load my Gatt View control, all Task start from same Start Date as Project Start Date or Start date of First Task.
While debugging in StartDateTime Property of Task I see incorrect Datetime.
But In StartDateTimeUnresolved Property of Task I see correct Datetime.
I even use AllProperties Column as though I am not storing any information in that cause I am Just information from Database.
Please let me know if you need more information.
Imran
You help me a lot, but if there is no solutions to this problem than I have to change my gantt view.There is lot of limitations in infra gantt view, many things are just fixed without any information.
I can say that, it is made to create tasks from itself not from other source i.e form.
Hello Mayank164,
It is very difficlut for me to say what should be the value, because there are stored information from many properties in binary format.
Let me know if you think that I can help you or if you have any further questions.
I agree with it, but in my scenario I am creating task from a form not from gantt view,so what value I save in AllProperties column from form?
