The editor supports multiple paragraphs, but when inserting text in the control, everything seems to be treated as a single paragraph. If you have a few lines, and then select a line alignment of Center then all lines are centered.
Is there a way to insert a new paragraph?
It is a user interfac eissue. I know that when the application insert text it can create multiple paragraohs by using <p>, and line breaks with <br/>. I want to enable the user of the form to be able to have more than one paragraph. Currrently the user can seelct bold etc, he can also select Line alignment to be centred. However everything he type is a single paragraph. so when you select centred alignment all the lines are centered.
Is it possible to extend the context menu so that I could add an Insert Paragraph item if there is no other way of doing this.
Hanve you tried using the Designer and simply pressing Enter in the edit window, then switching to the xml tab to see what tag is used? I thikn it's </BR>
