I am using a WinGrid with ValueLists as dropdowns. I have a grid with multiple rows. I would like to clear a selected value form some cells and set them to blank so user can reselect new values. I have tried: row.Cells[0].Value = ""; but I am getting can’t convert string to int error. I would like a cell to be in inital state when grid was loaded for the firts time – no selection(blank)
If I remember correctly I coundn’t create a blank valueListItem as it was by default setting description to value and I can’t dispaly that.
I am using a DataTable and DBNull.Value worked :). Thank you.
What kind of DataSource are you using for your grid?
If the field in the grid is an int (as it appears from the error message), then you cannot assign it an empty string. This is not related to the grid, it's the data source that limits you.
If you are using a DataTable or DataSet, then it will handle null values for you and the thing to do is set the Value of the cell to DBNull.Value.
