In Visual Studio design mode, I accidentally clicked the 'red x' on the UltraExplorerBar. In the form, it is now not anywhere to be seen and I have to get it back. The form still recognizes the control (in the dropdown of the properties window and all of the code is present but I simply cannot make it visible to the UI, again. By the way, both the enabled and visible properties on the property page are set to True.
PLEASE HELP ASAP
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
Could you please try to delete the contents of the 'License.licx' file in your project(not the file itself), clean and rebuild your application. You also could take a look if the assemblies you are using are from the same version.
Please do not hesitate to contact us if you need any additional assistance.
