Hi ,
I would like to know how I can initialize a numericserie ?.
I am using a ultrachart and each time I want to plot something with my macro the graph overlap with the previous one because the numericseries still keep info from the previopus graph.
Thanks for the code above all. It seems to be correct. Are you using your UltraChart`s designer for something ? Are you able to upload whole sample. I`d like to run and debug your sample. Are you able to capture a video which include application building and run time behavior ?
I am talking about the series itself, each time I am running my macro the series "keep" the previous data and I have two graph instead of one.
It is hard to it describe here is a sample of my scenario :
ChartArea area = new ChartArea(); this.ChartAlphaRealized.CompositeChart.ChartAreas.Add(area); // make a transparent color //PaintElement pe = new PaintElement(Color.LightGreen); //PaintElement pe_red = new PaintElement(Color.Red); //PaintElement pe_blue= new PaintElement(Color.Blue); PaintElement pe = new PaintElement(Color.LightGreen); pe.Fill = Color.White; PaintElement pe_red = new PaintElement(Color.Purple); PaintElement pe_blue = new PaintElement(Color.Blue); //column layers use a string, GroupBySeries x axis AxisItem columnXAxis = new AxisItem(ChartAlphaRealized, AxisNumber.X_Axis); columnXAxis.DataType = AxisDataType.String; columnXAxis.SetLabelAxisType = Infragistics.UltraChart.Core.Layers.SetLabelAxisType.GroupBySeries; columnXAxis.Labels.ItemFormat = AxisItemLabelFormat.ItemLabel; columnXAxis.Labels.SeriesLabels.Format = AxisSeriesLabelFormat.SeriesLabel; columnXAxis.MajorGridLines.Visible = false; columnXAxis.Visible = false; area.Axes.Add(columnXAxis); //line layers use a string, ContinuousData x axis AxisItem lineXAxis = new AxisItem(ChartAlphaRealized, AxisNumber.X_Axis); lineXAxis.DataType = AxisDataType.String; lineXAxis.SetLabelAxisType = Infragistics.UltraChart.Core.Layers.SetLabelAxisType.ContinuousData; lineXAxis.MajorGridLines.Visible = false; lineXAxis.Labels.ItemFormat = AxisItemLabelFormat.Custom; lineXAxis.Labels.ItemFormatString = "<ITEM_LABEL>"; lineXAxis.Labels.SeriesLabels.Format = AxisSeriesLabelFormat.SeriesLabel; area.Axes.Add(lineXAxis); //the layers can share the numeric y axis. AxisItem YAxis = new AxisItem(ChartAlphaRealized, AxisNumber.Y_Axis); YAxis.DataType = AxisDataType.Numeric; YAxis.Labels.ItemFormat = AxisItemLabelFormat.DataValue; YAxis.MajorGridLines.Visible = false; YAxis.RangeType = AxisRangeType.Custom; YAxis.RangeMax = MAxAlphaCumulValue; YAxis.RangeMin = MinAlphaCumulValue; area.Axes.Add(YAxis); //the layers can share the numeric y axis. AxisItem YAxis2 = new AxisItem(ChartAlphaRealized, AxisNumber.Y2_Axis); YAxis2.DataType = AxisDataType.Numeric; YAxis2.Labels.ItemFormat = AxisItemLabelFormat.DataValue; YAxis2.MajorGridLines.Visible = false; YAxis2.RangeType = AxisRangeType.Custom; YAxis2.LineColor = Color.LightGreen; YAxis2.RangeMax = Convert.ToDouble(VolumeNumeric.Compute("MAX(Volume_rate)", "")) * 1.1; area.Axes.Add(YAxis2); //Other possible approach for DataBinding VolumeNumeric = removecfd.AddMissingDaysVolume(VolumeNumeric); VolumeNumeric = removecfd.SortMydt(VolumeNumeric, "DATE ASC"); // place a fake volume at the first row of volume DataRow VolRow = VolumeNumeric.NewRow(); VolRow["Volume_rate"] = 0; VolumeNumeric.Rows.InsertAt(VolRow,0); VolumeNumeric = removecfd.DateToString(VolumeNumeric); VolumeNumeric = removecfd.killdoublevolume(VolumeNumeric); AlphaTable = removecfd.DateToString(AlphaTable); InitTable = removecfd.DateToString(InitTable); VWAP_st_Table = removecfd.DateToString(VWAP_st_Table); PC_st_Table = removecfd.DateToString(PC_st_Table); SectorTable = removecfd.DateToString(SectorTable); VWAP_sector_Table = removecfd.DateToString(VWAP_sector_Table); PC_sector_Table = removecfd.DateToString(PC_sector_Table); SectorPriceTraded = removecfd.DateToString(SectorPriceTraded); VolumeNum = removecfd.CreateSeries(VolumeNum, VolumeNumeric, "DateS", "Volume_rate", pe); ChartAlphaRealized.CompositeChart.Series.Add(VolumeNum); AlphaReal_st = removecfd.CreateSeries(AlphaReal_st, AlphaTable, "DateS", "Alpha_partial", pe_red); ChartAlphaRealized.CompositeChart.Series.Add(AlphaReal_st); seriesInit = removecfd.CreateSeries(seriesInit, InitTable, "DateS", "Alpha_Since_Approval", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(seriesInit); VWAP_St = removecfd.CreateSeries(VWAP_St, VWAP_st_Table, "DateS", "VWAP_Real", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(VWAP_St); ClosedPrice_St = removecfd.CreateSeries(ClosedPrice_St, PC_st_Table, "DateS", "Closed price Vs E300", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(ClosedPrice_St); seriesInit_Sector = removecfd.CreateSeries(seriesInit_Sector, SectorTable, "DateS", "Init Sector", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(seriesInit_Sector); VWAP_Sector = removecfd.CreateSeries(VWAP_Sector, VWAP_sector_Table, "DateS", "VWAP Vs Sector", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(VWAP_Sector); ClosedPrice_Sector = removecfd.CreateSeries(ClosedPrice_Sector, PC_sector_Table, "DateS", "Closed price Vs Sector", pe_blue); ChartAlphaRealized.CompositeChart.Series.Add(ClosedPrice_Sector); TradedPrice_Sector = removecfd.CreateSeries(TradedPrice_Sector, SectorPriceTraded, "DateS", "Sectors", pe_red); ChartAlphaRealized.CompositeChart.Series.Add(TradedPrice_Sector); ChartLayerAppearance columnLayer = new ChartLayerAppearance(); columnLayer.AxisX = columnXAxis; columnLayer.AxisY = YAxis2; columnLayer.ChartArea = area; columnLayer.ChartType = ChartType.ColumnChart; columnLayer.Series.Add(VolumeNum); columnLayer.SwapRowsAndColumns = true; ChartAlphaRealized.CompositeChart.ChartLayers.Add(columnLayer); ChartLayerAppearance lineLayer = new ChartLayerAppearance(); lineLayer.AxisX = lineXAxis; lineLayer.AxisY = YAxis; lineLayer.ChartArea = area; lineLayer.ChartType = ChartType.SplineChart; lineLayer.Series.Add(AlphaReal_st); lineLayer.Series.Add(seriesInit); lineLayer.Series.Add(VWAP_St); lineLayer.Series.Add(ClosedPrice_St); lineLayer.Series.Add(VWAP_Sector); lineLayer.Series.Add(ClosedPrice_Sector); lineLayer.Series.Add(TradedPrice_Sector); lineLayer.Series.Add(seriesInit_Sector); ChartAlphaRealized.CompositeChart.ChartLayers.Add(lineLayer); TradedPrice_Sector.Visible = false;
thanks
HI,
I`m not sure that I understand your scenario, but maybe you are talking about your Layer which contains your series. For example:
series2 = new NumericTimeSeries();series2.Label = "test2";series2.PEs.Add(new PaintElement(Color.Blue));series2.Points.Add(new NumericTimeDataPoint(DateTime.Today, 10, "test2", false));series2.Points.Add(new NumericTimeDataPoint(DateTime.Today.AddDays(1), 35, "test2", false));series2.Points.Add(new NumericTimeDataPoint(DateTime.Today.AddDays(2), 40, "test2", false));series2.Points.Add(new NumericTimeDataPoint(DateTime.Today.AddDays(3), 15, "test2", false));myColumnLayer2.Series.Add(series2);
If so, maybe you should exclude your series from the Layer. For example:
myColumnLayer2.Series.Remove(series2);
Could you please upload small sample with your scenario. I`ll be glad to research it for you. Let me know if you have any questions.
Regards
