I am having issues in setting the pressed-apperance of popupMenuTools. Can't seem to find the property that will do that. not on the tool itself nor in the app-stylist.
No mather what .isl file I load, when pressing a popupmenutool on a toolbar, it's style is just plain normal Office07 blue. the normal and hover work just fine.
Hello Jankol,
You are welcome.
The estimated date of the next service release where the fix of this will be included is 11 May 2012. If you would like you could take a look at our service release calendar please do it here:http://es.infragistics.com/support/service-releases.aspx#ServiceReleasesIf you have any other questions I will be glad to assist you further.
Ah ok! I get it now :)
Thank you for explaining. This is good.
When can we expect a service release where this would be included?
What you are seeing in the base version of the NetAdvantage for Windows Forms 2011 vol2 - 1010 is both an issue in the IG theme and the version itself, because the PopupMenu tool is not honoring the HotTracked appearance and showing something completely different - a style from Office2007Blue theme. Since this behavior is neither desired, nor expected, we have change it, so in the latest internal build it behaves as it should and now the PopupMenu tool does honor its HotTracked appearance in both scenarios - when it is being just hot tracked, and when it is being dropped down. I would like to apologize for any inconveniences that this caused you already.
If I could assist you further, I will be really glad to do so.
But in the test-project that I added for you earlier, you can clearly see that it is not the case.
The IG.isl style file, allready has a hotTracked image added to the PopupMenu tool, and it is only shown while HotTracked. When you PRESS the popupmenu tool, and it is dropped down, the color changes to something totaly different, office2007blue style.
So no, the HotTracked apperance does not change the droppedDown hotTracked apperance of the popupmenu tool.
Currently the PopupMenuTool is using the very same HotTracked appearance when it is being DroppedDown and when it isn't.
If you would like I could submit a new product idea for you, where I will explain the desired functionallity that you would like to our PopupMenu tool to have.If there is anything else that I could do for you please feel free to let us know.
