1745
Sort problem with bound grid
I have a grid that is bound to a DataTable via a DataAdapter.
After applying updates to the table I spin through the table rows checking to see if any of the rows failed to update. If they did then I copy the error message to the Tag of the corresponding grid row so that I can display it when that row becomes active.
This works fine if the data remains in its original order.
If the user sorts the data grid however it seems that the indexes of the the grid are no longer the same as the indexes in the underlying datatable.
The error messages get assigned to the wrong grid rows.
I though sorting effected only the display - not the index required to reference the grid rows.
How do I get the sorted index from the original (as in the underlying table) index?
My code is as follows:
adapter.Update(table)
Dim hasErrors As Boolean
For r As Integer = 0 To  table.Rows.Count - 1
If table.Rows(r).RowError = String.Empty Then
      'Remove the color that indicates pending changes
      Grid.Rows(r).Tag = Nothing
Grid.Rows(r).Appearance.BackColor = Grid.DisplayLayout.Appearance.BackColor
   Else
      'Add the error message to what we will display for the row
      hasErrors = True
      Grid.Rows(r).Tag = table.Rows(r).RowError()
   End If
Next
