1180
Layout serialization - howto set "defaults" ?
I'm trying to serialize grid layout. My intention is to keep user column filters, sorting, grouping (outlook groupby) and column widths for windows of same type (MDI).
What I try to do is: ultraGrid.DisplayLayout.Save(memStream,  PropertyCategories.ColumnFilters | PropertyCategories.SortedColumns | PropertyCategories.Groups) and it works almost fine.
Many of my grid properties are initialized at runtime - groups (row layouts), column header text, grouping, etc. I noticed that in some cases I loose column headers text and couple of other things set dynamically during form loads (probably because I deserialize layout of empty window into window that already has some data)
I found Mike's post that says : "... the saved layout only includes things that have actually changed - but by that I mean things that have changed from the default values in the grid - not neccessarily things that the user changed...", so I understand, that things done during window initalization (at runtime, not design time) will be serialized and deserialized as if user did this?
Is there a way I could tell to grid that "keep changes as default, and from now on track changes to be serialized" to distinguish user layout operations from "legal" ones?
