I have been trying all morning and cannot get this to work, i want the main menu (click on circle thing) that has multiple choices at the moment i get the dropdown list but the items on the right i cant seem to link to the item on the left if that makes sense?
Ie. In Word if you highlight Print Button you get different options as to if you highlight the Save button?
Any suggestions if you can understand my waffle :)
ayub said: The popmenu can auto adjust depending on the number of menu tool items in it. ... This is because you have only two Items added in the main Menu i.e. Manage and Exit. The size of the Manage popup menu is dependent on the Main Menu. As you will add more items in the Main Menu you will see the Manage popup menu also increasing in size.
Yes, the popup menu will auto size based on its contents. The only exception to this is when the popup menu is in the left side of the application menu. According to the Office 2007 UI Guidelines, menus sited on this side of the application menu must have a drop down which is the exact size of the right side and positioned over it. You can sort of work around this by adding LabelTool instances with no caption to the left side of the application menu under your two tools. This will increase the height of the application menu and as a result, the height of the popup menu's drop down will be increased as well.
Ur most Welcome
grrr thats annoying, not your fault but thanks for you help you have been great!
Thnks,
Hmm, i have added my controls to it but it still small only one item is displayed along with scrollbar button. Is there a property to set or flag?
See screenshot...
btw you are very helpful
