335
Performance Issue with Row Update using hierarchical Datasource
Hello everyone,
I'm having trouble with the following issue:
I'm using a DataSet as a datasource for my ultragrid. With the help of DataRelations I display the data in a hierarchical way with up to 4-5 levels. I have also the HeaderCheckbox in use to check all rows of one levels at once (the rows have a column of boolean type to check and uncheck). The problem is now, that when I check or uncheck a single row of the highest level, something happens that can take up to 10 seconds before the programm reaches the actual cellchange event. In similar cases there is also sometimes a long period of time between the before and after rowupdate events.
On lower levels the same procedure doesn't take so long, so I guess it has something to do with the hierarchical grid. Is there any chance to speed that up?
greetings
Renelope
