125
Problem with ContextMenuStrip in combination with UltraTextEditor
I have a connected a standard ContextMenuStrip to different controls. It works well except with the UltraTextEditor control. If I click in the UltraTextEdit control, the SourceControl obejct is empty.
If I rightclick on the UltraTextEdit control without clicking first (left) on the control, it is working like expected.
Thanks for help!
Cheers,
Herbert
Private
Sub ContextMenuStrip1_Opened(sender As Object, e As System.EventArgs) Handles
ContextMenuStrip1.Opened
mySourceControlName = ContextMenuStrip1.SourceControl.Name
'is empty if I click first in the cotnrol getting focus
ContextMenuStrip1.Items(0).Text = mySourceControlName
End
  • 469350
    Verified Answer
    The control is not empty, it's just that it has no name. When an UltraTextEditor control enters edit mode, it creates a child control and positions it over itself. This child control is a derived TextBox control which allows to the user to edit.
    So what you could do walk up the parent chain until you get a control that has a name.
        Private Sub contextMenuStrip1_Opened(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles contextMenuStrip1.Opened
            Dim contextMenuStrip As ContextMenuStrip = CType(sender, ContextMenuStrip)
            Dim sourceControl As Control = contextMenuStrip.SourceControl
            While String.IsNullOrEmpty(sourceControl.Name)
                sourceControl = sourceControl.Parent
            End While
            Debug.WriteLine(sourceControl.Name)
        End Sub
  • 48586
    Verified Answer
    When the editor is in edit mode we are drawing standard MS TextBox for input component, so you could easy avoid this behavior if you use code like:
    Dim mySourceControlName As String = ContextMenuStrip1.SourceControl.Name
            If TypeOf ContextMenuStrip1.SourceControl.Parent Is UltraTextEditor Then
                mySourceControlName = ContextMenuStrip1.SourceControl.Parent.Name
            End If
    in your ContextMenuStrip1_Opened event.
