785
UltraGrid messing up the localized languages when switching languages in the Designer
I'm localizing an UltraWinGrid v10.1.20101.1007 and I've got loads of issues while doing localization.
The grid is bound and if the data bound object changes (one of the sub objects had a property added) then all the language that I added was lost. It looks like a bug because I could see that VS checked out the default .resx file but didn't touch the localized resx file.
If I'm set to the localized version and update the bound object (by opening the designer for the grid) then it seems to be OK. However switching back and forth between localized and default languages just loses my localized version.
When I change from the language (nl-NL) to the default and back all my changes very frequently just disappear.
Am I doing something wrong or is there a bug in the grid?
Cheers.
