I'm using a composite chart which consists of 3 chart layers (1 columnchart and 2 linecharts).
I'm trying to use the zoom in/out feature but not able to do so.
I tried reading through the various posts in the forum but couldn't find the right answer.
In my designer, I have..
this.uChartGermany.Scrolling += new Infragistics.UltraChart.Shared.Events.ChartScrollScaleEventHandler(this.uChartGermany_Scrolling); this.uChartGermany.Scaling += new Infragistics.UltraChart.Shared.Events.ChartScrollScaleEventHandler(this.uChartGermany_Scaling);
in my code, I have..
private void uChartGermany_Scrolling(object sender, ChartScrollScaleEventArgs e) { foreach (ChartLayerAppearance layer in this.uChartGermany.CompositeChart.ChartLayers) { if (layer.Visible == true) { switch (e.AxisNumber) { case AxisNumber.X_Axis: layer.AxisX.ScrollScale.Scroll = e.NewValue; break; case AxisNumber.Y_Axis: layer.AxisY.ScrollScale.Scroll = e.NewValue; break; } } } } private void uChartGermany_Scaling(object sender, ChartScrollScaleEventArgs e) { foreach (ChartLayerAppearance layer in this.uChartGermany.CompositeChart.ChartLayers) { if (layer.Visible == true) { switch (e.AxisNumber) { case AxisNumber.X_Axis: layer.AxisX.ScrollScale.Scale = e.NewValue; break; case AxisNumber.Y_Axis: layer.AxisY.ScrollScale.Scale = e.NewValue; break; } } } }
I have put a breakpoint on each of them but when I click on the scrollbar or + / -, the events don't seem to be triggered.
However, I tried it on a normal LineChart and the events were triggered and it hit the breakpoints.
Any ideas anyone?
I`m glad to heard that you already solve your issue. Maybe will be interesting to take a look at the attached sample where you could find other possible approach to scroll your chart without using Scalling. Let me know if you have any questions.
Regards
Problem is fixed.
For some reason it works now after I deleted the original chart and created a totally new one.
Only difference this time was I created all 4 axis first before creating the chart layers.
Previously I created 2 axis, created 1 chart layer, and then created 2 more axis and created the next layer.
Not sure whether that was the cause.
