495
Problem with Column Headings UltraWinGrid Export operation
Hello, I am exporting the results of an UltraWinGrid to Excel. The Grid consists of two bands. Prior to calling the export, I set the HeaderPlacement of my 1st band to FixedOnTop then call the export. Here is the code: gvEmployeeEarnedHours.DisplayLayout.Bands[0].Override.HeaderPlacement = Infragistics.Win.UltraWinGrid.HeaderPlacement.FixedOnTop; ExportHelper helper = new ExportHelper(); helper.ExportGridToExcel("Earned Hours", gvEmployeeEarnedHours, Infragistics.Documents.Excel.WorkbookFormat.Excel97To2003); The ExportHelper is a reusable class I've created that simply calls the UltraWinGridExport object internally to perform the actual Export and nothing exceptional is written there to that would alter the data exported. When I open the exported file, not only do the column headers for band[0] appear on top, but in the 2nd row of the excel spreadsheet the column headers for band[1] appear, not exactly what I am expected (see the attached). Is there some way to prevent this from happening. Note, I am using the latest version Infragistics 11.2 CLR 4x.
Parents
No Data
Reply Children
No Data
