35
Underlying datasource doesn't support adding new rows
I am working with Entity Framework 4 and currently have a model consisting of many parent child tables. In the current scenario I am using a parent table called Lookups and a child table called LookupValues.
My Grid assignment statement is like:
grid.Datasource = entities.Lookup;
This is showing me the Lookups and LookupValues in the heirarchical format. I can even add/edit rows to Lookup band and I can also EDIT rows to the LookupValues (child) band.
However I am getting an error the moment I am clicking on the new row for the child band - "Underlying datasource doesn't support adding new rows".
Apart from the datasource assignment code as mentioned above, the only other code I have written is:
void ctlGrid_AfterRowUpdate(object sender, RowEventArgs e)
            OtEntities.SaveChanges();
I don't think this is a coding error and rather a glitch with the WinGrid itself. Or may be there are some other properties I need to set which I am missing.
