Hi!
Is it possible to produce a column layout similar to the following (I've used Groups and GroupBy extensively, but I'm still not sure this is possible..)
See attached image
Any ideas? Width wise, it'd be nice to span the lot across the screen.
Thanks, Tom
Have you been able to resolve your issue ? Did you have a time to take a look at the attached sample. Let me know if you have any questions.
Regards
I made a small sample for you. You could achieve desired behavior using UltraGrid`s designer or using a code. Please take a look at the attached sample and let me know if you have any questions.
Hang on, I've just found RowLayoutLabelStyle.... Bear with me...
