1745
Phantom node causes duplicates
My app adds nodes in 2 ways.
In one case it specifies both a key and text.
In the other it specifies text only (null key)
Occasionally [for no obvious reason] the tree is replaced by a large red X and a message box says
     Item has already been added. Key in dictionary: "Teradata SQL"
This occurs in response to an event - not due to a call from within my code. (It seems to be a Paint event - see trace below)
The problem is that I have searched my entire source base (including resource files) and the only time the string "Teradata SQL" is used it is used for the TEXT property - not the KEY.
Could the Tree somehow get confused if I am adding the nodes within a BeginUpdate/EndUpdate block and specifying a null key?
How can a paint event (which I have no handler for) cause it to attempt to add a node?
Is there any way to trap this error?
Maybe add a Paint handler that simply calls your paint handler from inside a catch block ... but I think it is too late by then.
Traceback:
System.ArgumentException: Item has already been added. Key in dictionary: 'Teradata SQL'  Key being added: 'Teradata SQL'
   at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
   at System.Collections.Hashtable.Add(Object key, Object value)
   at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.CacheNodeElements(Hashtable table, UIElementsCollection oldElements, Int32 startIndex)
   at Infragistics.Win.UltraWinTree.NodeClientAreaUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements()
   at Infragistics.Win.UltraWinTree.UltraTreeUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinTree.UltraTree.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Mike
