60
how to clear UltraCombo entry when cbo.dropdownstyle=dropdownlist
Hi Mike,
How can I clear the text of a UltraCombo int the entry screen when cbo.dropdownstyle=dropdownlist.  I'm not supposed to add empty row to the datatable.  Thank you.
Cs
  • 280
    Hi there,
    try this: cbo.Value = null;
    Also you can make a UNION select from your db: ex
    "SELECT null AS ID, '' AS DESCR UNION SELECT YOUR_ID AS ID, YOUR_DESCR AS DESCR FROM YOUR_TABLE "
    in that case you should set the cbo.Value = DbNull.Value;
    Hope that helped
    Nassos
