770
Summarize with criteria?
Hi guys.
I have a grid and at the bottom there is a sum of 1 column.
Is there any way that I can do to ignore some rows?
For example, I want to ignore the row that with 'Waste' text.
Parents
  • 71886
    Suggested Answer
    Hello engloon,
    If I got you right I believe that you could try out the following code sample and see if it meets your requirements:
            public class SummaryCalculator : ICustomSummaryCalculator
                private double total = 0;
                double notNeeded;
                public void AggregateCustomSummary(SummarySettings settings, UltraGridRow row)
                    notNeeded = 0;
                    if (row.Cells["Column 1"].Text == "Waste")
                        notNeeded += Convert.ToInt16(row.Cells["Column 0"].Value);
                    else total += Convert.ToInt16(row.Cells["Column 0"].Value);
                    Console.WriteLine("NotNeed: " + notNeeded.ToString() + " Total: " + Convert.ToInt16(row.Cells["Column 0"].Value));
                public void BeginCustomSummary(SummarySettings settings, RowsCollection rows)
                    this.total = 0;
                public object EndCustomSummary(SummarySettings settings, RowsCollection rows)
                    return this.total - notNeeded;
    Please feel free to let me know if I misunderstood you or if you have any other questions.
Reply Children
No Data
