The text display on the OverflowIndicator goes out of the screen while putting in large text in a multiline editor with ShowOverflowIndicator on. This was not the case in ver 7.2. The display used to fit in correctly depending on the size of the text. Pls see the comparison image.
Are we missing some property/setting that we need to set to make this work in the new version (8.1)
That sounds like a known bug which is fixed. I'm not sure if the hot fix has been released, yet. You should probably report the issue to Infragistics Developer Support and submit a small sample project demonstrating the issue. That way they can verify that it is fixed, or if not, get it corrected.
Submit a Support Issue
Sorry if the post was not clear. The issue is that the tooltip in the new version goes out of the screen towards the right and is partially visible. The same tooltip in version 7.2 use to align itself in such way that the whole text was visible.
It's a little hard to tell from these screen shots exactly what you mean. Do you mean the ToolTip is cutting off text? I beleive this is fixed in the latest Hot Fix.
If not, you should Submit an incident to Infragistics Developer Support
