Hey guys,
I know there is a built in ability to click on the tab within a pane and move it out creating a new Floating Panel. The problem is that we have a custom browser and when deployed into that browser this feature does not work. I know you can still double click to undock the pane, but that is unsatifactory for the application.
I need to know how to get the control that is attached to each tab so that I can force it to undock when the user drags it out. I am currently using the below code to get into the element, but beyond that I am completely lost.
Any and all help is appreciated, as always.
private void uDockManager_MouseEnterElement(object sender, UIElementEventArgs e) { if (e.Element is TabItemUIElement) e.Element.Control.MouseDown += new MouseEventHandler(OnControlMouseDown); }
Thanks for your response. Let me know if you have any further questions.
Georgi,
I apologize, I didn't get an email regarding your first post. However, I was able to get the control that was hosted in each pane using the MouseEnterElement of the UltraDockManager.
private void uDockManager_MouseEnterElement(object sender, UIElementEventArgs e) { if (e.Element is TabItemUIElement) { var tabElement = (TabItemUIElement)e.Element; var tabItem = tabElement.TabItem; _key = (from value in ControlsDictionary.ParentControls where value.Value == tabItem.Text select value.Key).Single(); e.Element.Control.MouseDown += new MouseEventHandler(Control_MouseDown); e.Element.Control.MouseUp += new MouseEventHandler(Control_MouseUp); } }
private void Control_MouseDown(object sender, MouseEventArgs e) { _mouseIsDown = true; foreach (var pane in uDockManager.ControlPanes) { if (pane.Key == _key) { _dragPane = new DockableControlPane(); _dragPane = pane; } } }
private void Control_MouseUp(object sender, MouseEventArgs e) { _mouseIsDown = false; }
private void uDockManager_MouseLeaveElement(object sender, UIElementEventArgs e) { if (_dragPane == null) _mouseIsDown = false; if (e.Element is TabGroupUIElement) { if (_dragPane != null && _dragPaneDockingArea != null && _mouseIsDown && _dragPane.DockedState != DockedState.Floating) { Point location = new Point(Cursor.Position.X - 150, Cursor.Position.Y - 22); _dragPane.Float(false, location); MouseAPI.MouseClickLeftUp(); Cursor.Position = location + new Size(150, 11); MouseAPI.MouseClickLeftDown(); _dragPane = null; _dragPaneDockingArea = null; } } e.Element.Control.MouseDown -= new MouseEventHandler(Control_MouseDown); e.Element.Control.MouseUp -= new MouseEventHandler(Control_MouseUp); }
I don't know if it is the best way to do what needed to be done, but it works. Thanks!
Have you been able to resolve your issue ? Let me know if you have any questions.
Regards
I`m not sure that I understand your scenario, but maybe you could take the desired control from ControlPanes collection. For example:
ultraDockManager1.ControlPanes[0].Control;
Please let me know if you have any questions
