i have a Projekt that copiles against CLR 4.0. Until now I use the clr2.0 controlls of IG.
What woud be the benefit of using the CLR4.0 Controllt. Are the more performat? Have the more posibilitys?
Best regards,
Wolfgang
Hello KPCN,
Thanks for your post.
Could you please give me more details about the exact version of the NetAdvantage controls used, your Visual Studio version, and if you could provide the exact errors it would be really helpful for further investigating the matter.
In case of other questions please feel free to let us know.
Hello Denko ,
Actually I m upgrading to CLR4.0 which gives me error Of No Definition Found For So n So Event Or Property for existing Infragistics controls , which is perfectly working fine with CLR2.0. What is lacking from side. Please let me know ASAP.
Thanks.
Hello Wolfgang,
If you have any other Infragistics related questions please feel free to contact us.
If you do not have any environment requirement to use only CLR 4.0 assemblies, than you could freely use the CLR 2.0 controls set.
If you have any other questions please do not hesitate to contact us.
Hello Danko,
so I dont have any reason to go to version 4.0 right now?
Oka!
Thanks a lot.
