18495
Update UltraProgressBar while executing long-running process
Not too long ago I had a case with a customer in which he wanted to know how he could update the UltraProgressBar during a long-running process.  I've decided to post the solution here so the rest of the community can benefit.
The best way to go about doing this is to use a BackgroundWorker to execute your long-running process.  I've attached a sample project which demonstrates this.  First, you need to create a method in which you'll update the progress bar and a delegate for that method:
private delegate void updateProgressDelegate(int percent);
private void updateProgress(int percent)
	ultraProgressBar1.Value = percent;
Next, create the method that will execute your long-running process:
private void someLongRunningMethod()
	int totalIterations = 5000;
	for (int i = 0; i < totalIterations; i++)
		int percent = (int)((float)i / (float)totalIterations * 100);
		Debug.WriteLine(i + ": " + percent + "%");
		this.Invoke(new updateProgressDelegate(updateProgress), percent);
		Thread.Sleep(5);
Now, handle a couple events of the BackgroundWorker to take care of starting the process and cleaning up after the process has finished:
private void worker_DoWork(object sender, DoWorkEventArgs e)
	someLongRunningMethod();
private void worker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
	ultraProgressBar1.Value = 0;
	ultraButton1.Enabled = true;
Finally, create the code to actually start the process:
private void ultraButton1_Click(object sender, EventArgs e)
	worker.RunWorkerAsync();
	ultraButton1.Enabled = false;
BackgroundWorkerProgress.zip
