Hi all,
i have an used infragistics wingrid having around 85 columns. If i group 10 columns and Resize the window, columns are hiding.How to overcome this problem? is it possible to set scroll bar for GroupoByBox?
Oh, I see.
Unfortunately, there's no way to add a scrollbar to the GroupByBox. You should Submit a feature request to Infragistics
sorry while resizing the window , the columns in the groupby box are hiding. How to overcome this?
You lost me. If you minimize a window, then everything is hidden. This should not have any effect on anything when you restore the window. And what does the GroupByBox have to do with it?
