I am using an UltraComboEditor
The UltraComboEditor is linked to a List<> where the DisplayMember is set to "Description" and the ValueMember is Set to "ID"
the ID is an integer and is stored in the relevant field on the table.
the UltraComboEditor is Styled as a DropDown, Autocompletemode = Suggest, AutosuggestFilterMode = Contains, Limit to List = true.
my problem is that when my form is initialised to edit a new record, where the value for the combo box has not yet been set the text of the combobox has defaulted to "0"
This is a pain as and "0" is not in the List and when the user starts to type, they have to delete the "0"
As a work around I set the UltraComboEditor.Text = "" where UltraComboEditor.Text = "0" in the Value_Changed Event, (though this will not work if an entry in the list begins with "0"!)
How can I get the UltraComboEditor to initialise to "" (string.empty) instead of "0"?
I don't want to give my users the ability to remove items from the valueItemsList.
I want to give them the possibility to type a value and the dorpdownList shows them all the possibilities to select. This works fine but then, I want to give them the possibility to edit the typed value.
For example, my user typed the value 300 but then he want to type "30". I want to know how to set the dropdownlist to the new values..
Most of my combo editors are linked to a lookup table in my database, so adding and removing entries from the selection are done by editing the lookup lists.
You can add entries to the list bycreating a new ValueListItem and adding it to the Items collection.
you can remove items from the list by using Items.Remove and Items.RemoveAt methods.
Im not sure why you would want to give a user the ability to remove an item from the list at selection time as surely its the value you are selecting that is important, not what you dont want in the list.
But you could probably catch the Delete key press event and then remove the selected item?
I read in this posts that you have a ultracomboEditor that allows your user to insert and delete a value.
I need to know how to let my users delete a value on my ultracomboEditor.
Can you please teel me how do you did that?
Thankyou!!!!
that is standard expected behavior. DevExpress has a field call NullValueText and you can set there what you want to display...which is usually an empty string or a message to user like...Please make a selection.
They allow you to set the type of the "null value" and expected null value ...so for example in this case it would be an integer since a new manager defaults integers to 0...this is nice for custom scenarios but usually just setting the NullValueText to empty gets most all cases.
I have started on a short term solution to the 0 problem
I have added an inherited UltraComboEditor to the project (udUltraComboBox)
I have hooked up the InitialiseDataItem event to reset the text. I selected this event as it is the only one (I found) that fires after the initial value is set, but not called constantly during the controls lifetime.
There probably is a better event/way to do this, isnt there.... ?
