I have recently updated my application from infragistics version 10.1 to 11.1
When i try to open any designer of the form,its is giving error.I found that contentsof license.licx file still has references to infragistics v10.1 version dlls.How can i remove the older contents in this file?.I have added references to the new dlls in my project.Should it reflect back in license.licx file? or do i need to add it manually?
Hello dsasid,
I am glad that you were able to resolve your issue.
If you have any questions in the future please do not hesitate to contact us.
Hello Danko Valkov,
The error is resolved now.It was issue with the path in which the application was located.
Thanks for the help .
If the content of the Licences.licx file is empty, could you please open the "References" of your project and verify if all of the references are pointing to the same version of our controls?
Also could you please click on the "Error list" in the bottom left corner, and provide me the error text, in order to verify what is happening in your application.
I tried the above steps.Still i am getting error in winform designer.I have screenshot of the error for further references
Hello Dsasid,
You could freely remove the Infragistics contents of the licenses.licx file and clean and rebuild your application. There is no need to manually enter the references there. When gets necessary the application will automatically populate this file for you.
After upgrading you could remove the Infragistics content from the file.
Please feel free to let me know if you have any other questions with this matter.
