Am using Ultra panel in my project and add few control inside panel, when checking some condition i want to hide the panel in the form and squeeze the space when enable then use the space is tat possible, becos i have done same with ASP: Server control.
OTHER CONTROL
________________
PANEL CONTROL
BOTTOM CONTROL
____________ H
panel I
D
____________E and Merge the space
pls help
Regards
cyus
I just wanted to know if you were able to solve your issue based on my suggestions or you still need help?
Just let me know.
Thank you.
Hello ,
From the description of your issue it seems to me that you have need to use UltraExpandableGroupBox. More information about this component you could find on the following links:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.2/CLR2.0/html/WinExpandableGroupBox.html
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.2/CLR2.0/html/WinExpandableGroupBox_Add_Controls_to_the_WinExpandableGroupBox.html http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.2/CLR2.0/html/WinExpandableGroupBox_About_WinExpandableGroupBox.html
Please review the previous links and let me know if this is the component which you are looking for.
