100
Tab Functionality Question
Good afternoon. I have 2 questions relating to tabs and the WinGrid.
1. When you tab from another windows control to the WinGrid which setting within the WinGrid allows the focus to switch over to the first WinGrid column then allow column navigation through the first row before jumping out of the grid to the next control? My grid receives focus but when the tab is pushed on the keyboard focus is maintained row by row instead of through the columns.
2. If I click within the WinGrid columns to gain focus in the first cell then I hit the tab my grid tabs across the columns until I arrive at a particular column. Once I reach this column (not the end - 8 more cols to go) focus jumps out of the row and to the next control. What would cause the grid to think a designated column is the end or jump out of tabbing? Also, if you click at the last column cell in the WinGrid and tab backwards (shift + tab) the grid properly traverses through all of the columns and doesn't jump out of the row. Any ideas what to verify / check?
Thank you, Christopher
  • 53790
    Hello Christopher,
    I try to reproduce your scenario with the latest version of our controls - 11.2.20112.2019 and I didn`t met any unexpected behavior. Could you please take a look at the attached sample and video file and if you think that I didn`t reproduce your scenario, feel free to modify my sample and rewvert it back to me. I`ll be gald to research it. Also if you are using older version,, you could downlaod our latest version from our site: Infragistics.com -> MyIG -> MyKeys and Downloads.
    Regards
    UltraGridTabOrders.zip
