I have run an application with Infragistics 11.2 on a pc, and later revert the application to referring to Infragistics 10.2. I got the following error when the application tried to load the wingrid layout
"Could not load file or assembly 'Infragistics.Win.UltraWinGrid, Version=11.2.20112.2004, Culture=neutral, ...' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference."
The application refers to Infragistics dll on its application directory and not GAC. The layout was saved as compatible to NetAdvantage 11.2, and when application with NetAdvantage 10.2 tried to load the layout it got an error. Shouldn't it backward compatible?
Hello Hertel,
If the UltraGrid designer doesn't appear on the Form, this most probably means that the Visual Studio is not able to locate the Win.Design assembly from the GAC of the machine that you are using 11.2 version of the assemblies.
Could you please verify if the Design assemblies are installed correcty in the GAC?
hi
There is no old assemblies in the bin and obj folders, licenses.licx is cleared. And i have cleaned n rebuilt several times.
The application referring to 11.2 just can't load UltraWinGrid layouts from 10.1 or 10.2. We are stuck and we need a fix as soon as possible.
It seems to me that in this case there is still old assmeblies in the Bin folder of the application. Please remove the bin and obj folders from your application if there isn't any sensible information, and rebuild the application one more time. Also please take a look at the licenses.licx file for any old referencing information remain there, and clear the content out.
If you still have any other questions please feel free to ask.
hi, I am referring to the assemblies in a specific folder, and Copy Local is set to true.
I got another error today. I have an application referencing NetAdvantage 10.1, and after being upgraded to 11.2, it was not able to load the ultrawingrid layout.
Unable to find assembly "Infragistics.Win.UltraWinGrid, Version=10.1..."
Application refers to Infragistics Version Free Assemblies in specifi folder, copy local set to true.
Could you please let me know from where you are refering the controls that you are using in your application? From a specific folder or directly from the GAC?
If you are refering them from a specific folder, how is the Copy Local property being set?
Please feel free to let me know if you have any other questions.
