80
Setting ultratree top node causing unwanted scroll bar behavior
Hello
I'm trying to maintain the scroll position of a ultratree after updating nodes and such. Now I've seen in many places the recommendation to use the TopNode property to do this. However when I do this the scroll bar is scrolling to the top even if there are nodes above the newly set top node.
To illustrate with a trivial example. I have the following tree:
If I then set the TopNode to node "c0" I get this happening:
This is obviously unwanted behavior because it make it look like there are no more nodes above.
Any ideas?
