350
How disabled default options on popup menu...
This control (UltraExploreBar) has default values ​​by clicking the right mouse button, such as adding a group, and other item.
I have a particular contextual menu associated with this control.
When I do right click the control menu appears first by default and then my custom menu.How I can disable the default menu control ultraexplorebar?
Thanks ....
  • 53790
    Hello Xavendano,
    Maybe one possible approach to achieve the desired behavior is to handle these two events:
    private void ultraExplorerBar1_NavigationContextMenuInitializing(object sender, Infragistics.Win.UltraWinExplorerBar.CancelableNavigationContextMenuInitializingEventArgs e)
        e.Cancel = true;
    private void ultraExplorerBar1_ContextMenuInitializing(object sender, Infragistics.Win.UltraWinExplorerBar.CancelableContextMenuInitializingEventArgs e)
        e.Cancel = true;
    Regards
